When click on View cube, drawing reduces in size so that I am barely able to see it. Any thoughts? TY
nnakovich
Observer Observer
nnakovich
Observer
Observer
ryan.bales
Autodesk Support
Autodesk Support
Its likely there is an object very far from the origin or from the other objects you are working with.
Ryan Bales
Fusion 360 Product Support
nnakovich
Observer
Observer
Thank you. Any thoughts on how I find this object to delete it? TYVM
ryan.bales
Autodesk Support
Autodesk Support
Freeze/hide everything where you are normally working, then use zoom fit/viewcube. Theoretically it should zoom you to the right location of the objects.
Ryan Bales
