Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
What factory in Frankfurt can work with 3D CNC?
Message 1 of 8
Hello forum!
I have been working for following speaker baffle with hobby machine. I have completed one of the pair. But the hobby CNC machine has caused too many troubles and I understand that my work is way too much for the machine. Now I look for a factory which can cut the other piece of my speaker baffle.
I have 3D data created with Fusion 360. I have done many test cutting and adjusted the data. I have walnut wood. Please let me know good factory which can work with 3D CNC ! (I live in suburb of Frankfurt. So around Frankfurt is better but not limited to the area if the factory is helpful.)
Note: There are curved surfaces
@Anonymous  The title has been edited for better findability by @michele.mk. Original: Erzählen Sie mir bitte eine gute CNC-Fabrik für 3D-Holzschnitzerei!
Replies (7)
Message 2 of 8
g-andresen
this is not a task for a factory but for a joinery with CNC.
Either you will find the corresponding companies in the frankfurt business directory or you can post the question at "wood-cnc ".
günther
Message 3 of 8
Hello Günther!
Thank you very much for the reply!
I looked for places which have CNC, but they mostly work only with 2D and they hesitate to handle 3D. As well, they don't use Fusion 360. I can convert the data to DXF and DWG, but I am not sure how it is accurately converted. So I think I had better to look for places which accept Fusion 360 and handle 3D data.
I will post the question to the forum you told me too, Thank you!
Message 4 of 8
g-andresen
Anyone who runs a cnc is reluctant to use foreign data that has not been tested on their system.
Furthermore, there are only a few postprocessors available for Fusion for the market-leading machines (Weeke, Holzher, SCM, Biesse ...). I only know one for the woodwop system and it doesn't work on all versions.
regards
günther
Note: I wouldn't load data on my machine whose structure I can't judge.
Message 5 of 8
TrippyLighting
3D data is usually exchanged in the form of STEP files, not dxf or dwg.
A company that is accustomed to work with 3D machining will likely also be able read a number of 3D data formats.
.stp (Step) .igs (IGES) .x_t (Parasolids) .sat (Acis) are the most commonly used formats.
They will also likely use their own CNC programming to create tool paths.
Message 6 of 8
Thank you very much, Günther
It means that I had better not expect that those who can handle Fusion360 would be minority....
Noted. 🙂
Message 7 of 8
Hello Peter,
Thank you for the reply. I also heard that .stp and .igs should be handled by those who handle 3D CNC. Fusion360 data can be converted at Autodesk website. I will submit the data to the carpenters. By the way, do you know such carpenters who work with 3D-CNC machine?
Zenigata
Message 8 of 8
g-andresen
there are basically 2 ways:
1. give the 3 d data to the joinery > they create the toolpaths for the specific machine with a CAM module.
Finaly the part will be manufactured.
2. You want to create the toolpaths yourself.
Then you have to have a list with tool numbers and data from providers and Fusion has to provide a postprocessor for this system.
I think that only the first way makes sense, because the second way has the problems mentioned above.
Nevertheless
much success
Translated with www.DeepL.com/Translator
