Went to "share" a design after saving and it reports "Your file couldn't be accessed" and hangs
billupsrothenbergfusion
I finished a part I was modeling and went to share the link with a coworker and I got the message you can see in the screenshot below. And fusion is frozen now.
The infuriating part is that it used a modal dialog with no cancel/close/exit button or similar. Cause it didn't look like fusion crashed, its just hung waiting to exit the unexitable window! I'm REALLY glad I saved cause otherwise I could have lost data!
tasha.addington-ferris
Autodesk Support
Autodesk Support
Hey @billupsrothenbergfusion, were you able to create the share link after restarting Fusion or is this continuing to be an issue? Additionally, do you have any issues making a share link using the Fusion web browser instead?
Tasha Addington-Ferris
Autodesk Fusion
Technical Support
After I kicked it, I was immediately able to share,
The "bug" that needs fixing, in my opinion, is the alert dialog that can't be exited from.
Autodesk Support
Autodesk Support
Gotcha okay glad that's working for now at least. I can report this to developers to look into but a little more information would help them. Can you gather your Fusion Diagnostic Log files and either post them here or DM them to me?
Autodesk Fusion
Technical Support
Thanks, here's my logs. Issue occurred on 3/17/2025 roughly around 7:30PM PST
Autodesk Support
Autodesk Support
Got them, thank you! I'll share these with the team. 👍
Autodesk Fusion
Technical Support
