Weird Groove
Weird Groove
derektan958
Weird Groove
derektan958
Community Visitor
Community Visitor
I wanted to make a groove (3mm width, 1mm depth) on a 1672 mm plate (20mm thickness). I sketched the shape and revolved it, at the end I got a very weird groove, can someone help?
seth.madore
Can you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
TheCADWhisperer
But to make sure that it isn't a geometry issue rather than a graphics issue you should always Attach your file here.
If the data is proprietary then make up a dummy file that exhibits the same issue.
Also - you have at least one dimension that does not make logical sense in the real world.
