weird annoying problem with viewcube
tony.dove3
tony.dove3
my fusion360 seems to have a problem with the viewcube  "sticking" all the time when moving orientation .
when holding mouse button down  .. normally when i let go of said button i can get on editing my models but lately since all these new updates..  ive been having this problem when letting go of the button the movement of the mouse (without no buttons pressed) somehow has locked onto the viewcube so all movement of the mouse moves the display and i cant seem to get out of it  ...unless i stop and restart fusion ..fusion worked flawlessly before these "Improvement" updates . its a right pain as doing this all the darn time  makes a 2hr model design last over 5 hrs or more !!!
I would like to know does / has anybody else experienced this annoying problem since these (supposedly) improvement updates ??
g-andresen
please show this behaviour in a screencast
günther
tony.dove3
Hi ive never done a screencast how do i do one of them ?? 😐
tony.dove3
Update ..autodesk has wrote back to me explaing that they are aware of this problem and are in the process of trying to find the cause ...
This is a part of a  copy of what i was sent >>>>
At this time I can only recommend you try any of the 6 methods to orbit to see if something works better for you than your current experience with the view cube. This is an issue that has our attention but certain technical problems prevent any work on it recently. Sorry for any inconvenience while this is sorted out.  !!
So there ya have it ...its a problem withing fusion which i still think the updates are to blame as my old version worked just dandy !!
adprotection
Observer
Observer
I have the same problem on a Mac.
The workaround using a mouse for orbit doesn't work as my Magic Mouse doesn't have a middle mouse button.
davebYYPCU
Yes happens to me - no apparent reason - don’t remember what starts it,
menus still work but model is permanent orbiting with the cursor if the cursor is returned the window
can only close and reboot Fusion.  Windows 10.
When it happens you do not think to Screencast, If that is possible?
