Warning: Selected joint type will result in conflict (it says this)
aarbon001
aarbon001
Community Visitor
Community Visitor
I was designing a DH bike frame on fusion 360 and I needed to check how was the suspension system reacting so  I did a joint system to look the movement, but when I was doing the last joint, in the program popped up this error: "Warning: Selected joint type will result in conflict" and it didn't let me move the desgin. Would anyone be kind enough to check my design and tell me what am I doing wrong please?
Here is the link to my design: https://a360.co/4cMOHUp
jhackney1972
You can make one side work by using a Cylindrical Joint for the last connection.  There is an alignment problem along the axis that prevents the use of a Revolve Joint.  As far as the other side, you are going to have a difficult time creating any type of rotating joint as the upper end hole of the mechanism is NOT Round.  The model with the one side fixed is attached.
John Hackney, Retired
