Warning: Old material could not be removed from the document, possibly because it is the default material.
- Mute
- Permalink
- Report
The STEP files I receive from customers are, for the most part, defaulting to Steel as the physical material. When I try to change it to something else, I get random results. Sometimes it works, other times it fails with the above warning because apparently in this context default means something else than "implicit selection in case nothing else is specified".
The only thing guaranteed to work: deleting part's "default" material, which gets replaced instantly with Fusion's default, which in my case is Aluminium.
I don't understand how a bug/limitation for something this basic is allowed to persist for so long in the product. Especially now that in the Manufacturing workspace they are actually taking the material into consideration for selecting e.g. feeds and speeds. So it should be easy to set the material as part of the workflow. But it is not.
