Warning Compute fail
barabm
barabm
As I updated a updated a User Parameter, I received a warning at it failed to compute and solve. However, it seems like the model actually got modified as expected... Can I keep going as nothing happen or will this cause issues later on.
I'm somewhat surprised by the warning since the updated parameter is simply the change of the extrusion of a profile. I can't see what could be that wrong about that problematic sketch. Especially if it extrude in the first place.
thx
davebYYPCU
If the sketch has gone bad, needs fixing.  Before saving the file, you can fix it with UNDO (repeat) until the change is removed.
Whether the Extrude updated with a bad sketch is unknown.
Might help...
