Very Frequent Crashing (3 times in 20 min) on Mac OS w/Error Reports
motorvategarage
motorvategarage
On my last project in February, Fusion 360 was rock solid.
However, something has changed and Fusion360 (v2.0.10356) crashes almost every time I try to save a file when in 2D PCB section.
This is an electronics project with schematic, 2D PCB, and 3D PCB.
I am on a "Trashcan Mac Pro" with 64 Gig ram, running Catalina 10.15.7 (with all the latest updates)
Here is what I have tried so far:
• Boot into safe mode / clears font caches and other clean up
• Re-install 10.15.7
• Clean install on other Mac Book Pro (10.15.7) and it also crashed when saving 2D PCB section.
• Created new admin user, clean install of Fusion360 and it still crashed.
• Tried editing previous project (that never crashed) and it crashed
What else can I try to resolve this?
Here are my error report IDs by date/time and brief description:
Jun 27/2021
308006717  @ 15:44 Worked perfectly editing schematic for hours, Switch to 2d pcb and crash.
June 26/2021
307984208  @ 20:31 Tried to select different layer > crashed
307984013 @ 20:13 tried to add a 4 pin header > crash
307983929 @ 20:04 saved project from project tab > crash
307983535 @ 19:14 moved connector on 2D pcb view > crash
307982661 @ 17:04 switched tabs > crash
307982550 @ 16:49 crashed after refreshing file panel
307982283 @ 16:16 crashed after restarting from a crash
307982263 @ 16:13  switched from PCB to schematic tab > crash
307981898 @ 15:35 tried to saved PCB > crash
June 25/2021
307954789@ 16:56 editing a library component > crash
307948503 @ 12:46 (MBP 2015)
307948333 @ 12:40 (MBP 2015, new install)
307948035 @ 12:30 > crash
307947467 @ 12:13 > crash
307947179 @ 12:05 after safe mode boot & new admin user > crash
307946194 @ 11:38 > crash
307945688 @ 11:26 > crash
307943055 @ 10:27 > crash
307944579 @ 11:00 > crash
June 24/2021 error reports:
307897942 > crash
307897795 > crash
307896418 > crash
307898191 > crash
307898848 @ 18:49 > crash
Graphic Details:
[GPU Information]
GPU Device: AMD Radeon HD - FirePro D300
GPU RAM: 2048 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: Off
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Thank you in advance!
rohit.bapat
Hello @motorvategarage
Sorry to know that you are facing these crashes.I can see that majority of the crashes caused while saving a milestone.
I found that for following reports there is already a ticket FUS-84773 for following reports. The good news is that the solution for this issue has been found and should be available soon. Unfortunately I won't be able to commit to any particular update but I can see in our system that the issue is fixed.
Meanwhile can you please check if you are able to save the file without Milestone?
Rohit Bapat
Product Owner
motorvategarage
Thanks to the excellent support from Panpan all is well.
Here is what he told me to do:
Create a new electronics project and import a COPY the schematic and 2D pcb.
Then create 3d pcb and save WITHOUT creating a milestone.
So far, this seems to work.
Thanks for the follow up.
