Vertical lead-in radius feedrate
03:39 PM
I noticed an inconsistency in the lead-in / lead out vertical feedrates. I am not sure if this is intentional and would like to understand more the reasoning behind it.
When using vertical lead-in radius option, the path generated is actually going at the ramp speed.
This doesn't happen to the vertical lead-out, which is performed a the lead rate.
This is causing an issue because my Z axis max feedrate is slower than X & Y. The lead-in radius at ramp speed means the Z axis has to move at full ramp speed just at the beginning of the radius. In practice, it makes the Z stepper stall.
Is this intended behaviour? if so, can anyone explain why?
