Using Parameters in Flat Pattern
jamieSW32L
Message 1 of 1
jamieSW32L
How do I use the defined user patterns from the primary 3D model in the flat pattern sketch environment? Is there anyway to call a user parameter from the 3D model to use in sketches on a flat pattern?
For example, our custom fuel tanks are almost 100% generated by a parameter table, which includes thickness and baffle spacing for fuel tanks in the 3D model creation. When I create the flat pattern for the fuel tank, I also use a sketch to create engraving lines which indicate where the baffles should be located. I have to lay this out manually for each tank, but if I could use my user parameters, it would be automated in the template and save 5 minutes for each tank.
Replies (0)
