Using Fusion 360 on work laptop
I am currently using Fusion 360 on a enthusiast licence for small personal projects. I would like to install Fusion 360 on my work laptop as it is much faster than my personal laptop. I work for a large engineering company, will having the software on my work laptop break the terms of use? It says maximum turn over $100k and my company turns over many times that. Is that a problem as long as I am only using it for projects unrelated to my job?
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
I believe as long as you are using Fusion for your personal/side work and not for company projects, you are in the clear. If your company is asking you to do work, then we would request that you purchase a license. Here is a link to our legal terms of service if you would like to look through those.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
Hi Karina,
Thank you for resolving my question so quickly.
Kind regards,
Jack
thegwydd
Community Visitor
Community Visitor
I have the same question of the OP but I'm confused by your answer. You said "I believe" but is it something officially confirmed or it's your interpretation of term of service?
Thank you
