User Parameters does not work in features?
SamsonW_
Message 1 of 8
SamsonW_
Previously, I can create user parameters let's say "Length = 10mm" and use it as extrude distance, shell thickness, offset a sketch profile, etc. After the most recent update it seems I can only use user parameter in dimensioning a sketch?
Need help as this is the most efficient way to quickly change multiple values of a model and get it to update instantly.
Update: It doesn't work if I'm editing in place in an assembly. But seems to work if I'm editing the component outside of an assembly. Which seems like a bug to me.
Replies (7)
Message 2 of 8
CGBenner
@SamsonW_
Welcome to the forum, and thank you for sharing this.  I have moved it to the Fusion Support forum for better visibility.
@RajkumarIlanchelian can you take a look at this?
Chris Benner
Message 3 of 8
RajkumarIlanchelian
@karina.harper Karina, can you please look into this edit in place issue ?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @SamsonW_ , this seems to work for me. Can you share a video or more context about when this isn't working for you?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
Message 5 of 8
SamsonW_
So I created an external part and started edit in place
Also created two user parameters:
Tried to use the parameter in a sketch, no problem:
Tried to use it with an extrude feature, doesn't work:
Same thing if I try to use that parameter in a sketch with offset:
When testing these, I realized it's the auto complete feature that is broken, not the user parameter. And the name of the user parameter is actually case sensitive. You can see in picture 2 it worked in sketch even when I typed in small case.
ā€ƒ
ā€ƒ
ā€ƒ
ā€ƒ
Message 6 of 8
CGBenner
@karina.harper
Were you able to take another look at this?  DO you need more information from @SamsonW_ ?
Chris Benner
Message 7 of 8
karina.harper
Autodesk Support
Autodesk Support
I can reproduce this behavior. I think this was a general problem previously that we fixed, but it looks like it stuck around in EIP. I'll log this with the team.
Thanks!
Karina
Karina Harper
Message 8 of 8
karina.harper
Autodesk Support
Autodesk Support
Logged as FUS-153621
Karina Harper
