[Urgent] problem with notebook shutdown when using Fusion 360
sajjapongse
sajjapongse
Dear Autodesk
I have an issue with Fusion 360 lately.
Whenever I rotate or zoom the object, especially the one with many parts, my notebook is shutdown (instant black screen).
I did try to clean uninstall the program the result still the same.
I then try to format my computer and reinstall fusion 360 but the result still the same.
The latest graphic card driver is already installed, and I do diagnostics all my notebook several times, but everything is fine.
This is the first time the issue happen to me. I need to back to my work in the company asap; please help me find the solution.
Below is the notebook spec.
Dell precision 3510
Processor Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz 2.60 GHz
Installed RAM 8.00 GB (7.89 GB usable)
System type 64-bit operating system, x64-based processor
Graphic card AMD Radeon (TM) R9 M360
Edition Windows 10 Pro
Version 20H2
Installed on ‎9/‎27/‎2020
OS build 19042.572
Experience Windows Feature Experience Pack 120.2212.31.0
azimshaikh95
Hi @sajjapongse
I'm not sure this will solve your problem completely, But I would like to suggest you open Fusion 360 with Integrated Graphics (ie. Open App which does not use External Graphics Card). Maybe it will resolve / you can find the issue.
Please post here if is there any updates. I'll try to resolve at my best.
Thanks & Regards,
MohammedAzim Shaikh
 Please use the Accept Solution button to mark any posts that provide the answer or solution.
 Likes are always welcome.
 LinkedIn | Instagram | Facebook | YouTube
sajjapongse
Thank you for your reply  @azimshaikh95
The [run with graphic processor] option is not available on my notebook for some reason.
I instead disable the AMD graphic card and force Fusion 360 to use an integrated graphic card.
The Fusion 360 seems to work fine now. I think the cause has come from the AMD card after all.
I will continue to use the program to make this will continue to work.
Thank you again.
Best regard
Krittanai Sajjapongse
azimshaikh95
If you got your answer, please use 'Accept Solution' so other users can get it.
Thanks & Regards,
MohammedAzim Shaikh
