Uploading file 2,3GB
Hi Team,
I have 2,3 GB .step file from Solidworks and when I try to upload it via Fusion360 application - I receive "failed" status.
Then I found a solution to upload it via Autodesk Account (or F360, does not matter, anyway - uploading via WWW). And I received this file, but still can`t open via Fusion360 app. It seems to be just a link to my web account. Please check attached screenshot - there is a icon next to file name. What does it mean and how to open it?
Thank you in advance.
Mariusz
ryan.bales
Autodesk Support
Autodesk Support
First we have a 2gb upload limit Unable to upload files larger than 2GB in Fusion 360. Secondly, if that file was somehow uploaded in STEP format you 'might' be able to right click and select 'create Fusion Design' - i've not done that in quite sometime i do not recall the complete limitations in file type.
Ryan Bales
Fusion 360 Product Support
Hi, thank you for your reply. It is a .step/.stp file. By clicking "Create Fusion Desing" I receive a "failed status" with "Max attemps with no progress" 😞 What to do?
ryan.bales
Autodesk Support
Autodesk Support
Really the file needs broken apart or simplified before attempting to come into Fusion. Another program would need to be utilized to do that.
Ryan Bales
