Uploaded Files Can't Be Edited
kyle4L9E9
Message 1 of 14
kyle4L9E9
Hi All,
I've been having an issue where existing CAD files uploaded to Fusion or opened from my computer (STEP, STL etc) cannot be edited in Fusion. I cannot rotate/zoom/pan in the new file with my mouse (although I can with my 3d mouse), or perform any editing functions (sketch, extrude etc.). If I right click on model in the browser, Fusion crashes. As a result there is no way to turn modelling from direct to parametric.
This issue can be bypassed by making a new assembly, then putting the file into it and editing the file in the assembly context, or by using 'save copy as' from the assembly menu then opening the saved copy. Saving the copy is the only way to allow capturing of design history.
I have tried opening these files on a different computer and everything seems to be fine, so I'm guessing it's a specific setting somewhere that's different.
Any help would be appreciated.
Windows 10, 32GB ram, 512SSD + 2x2TB HDDs, 1060 graphics, I7-6700, not sure where I go to check fusion version but it updates frequently.
Cheers,
Kyle
  • Bugs
Replies (13)
Message 2 of 14
Phil.E
This sounds really strange. I work on crash issues and this is new to me. Do you get a crash error report (CER) when this happens?
Can you possibly share one of these designs? Use File > Share > Share public link. If it's private, you can always send via PM to my forum inbox. Or just attach one here if you can.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 14
kyle4L9E9
Thanks for the response Phil.
Yep no problem, I've created a simple box that triggers the issue (attached here), as it happens with any STEP or STL file. Made the box in fusion, exported it as a step, then uploaded back into fusion and can't edit it. I've attached the F3d, I can upload this and then edit it successfully.
In terms of error report I get one if I trigger it into crashing by right clicking on the browser, but otherwise not. Would you like me to force crash it to get you an error report?
I probably should also mention that this issue has been happening for a while now (at least 2 months?), so I don't think it's related to any recent updates. Starting to wonder if it's going to need a clean uninstall/reinstall, although I would prefer to avoid that if it's something fairly simple.
Message 4 of 14
Phil.E
Thanks for the files. I'll try to reproduce it.
If you could please take a moment or two to reproduce it again that would help. I did find an older report (thanks for sending those!) but at this time it would be good to compare with a new report.
In general, always send every CER report please, especially repeated crashes. If the systems I use detect repeated crashes they get attention faster. It's impossible to do this without automatic detection of such patterns.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 14
jhackney1972
I used your Fusion 360 file to create a STP, imported the STP and edited it without issue.  Opened up the supplied STP file and edited it also without issue.  I am using the recent Fusion 360 update 2.0.9640
John Hackney, Retired
Message 6 of 14
Phil.E
Thanks @jhackney1972  for giving it a try.
@kyle4L9E9  I'm finding the same thing. I'm also not finding new crash reports like yours. Please do try to get a new report to look at. And just double checking, can you please also see what build you are using, on the Help > About menu?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 14
kyle4L9E9
It definitely does seem to be a problem very specific to me eh...
Version
2.0.9636
Also updated to
2.0.9642
Same problem
Just forced a crash again as requested, workflow as such:
Open fusion
Upload Test Box.stp
Open Test Box.stp
Right Click on the browser
Crash
Error report 300000543 - Version 2.0.9636
300000588 - Version 2.0.9642
Thanks for taking the time to look into this guys, appreciate it.
Message 8 of 14
Phil.E
Thanks for sending those reports. Nothing jumps out, but I'm not done with them.
Do you have any kind of non-default add-in running? Or any kind of special CAM settings or extensions?
And just to be clear, how exactly are you opening the designs when it does this? Which workflow are you using:
  • File > Open > (open a stp/stl)?
Or are you using
  • Upload > Open resulting file from the data panel
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 14
kyle4L9E9
So to answer your questions:
Nope nothing non-standard, it's just a pretty vanilla setup with mesh workspace turned on.
In terms of workflow, I've tried both and get the same result either way, not 100% right now but I think those reports were generated using Upload>open
Thanks again
Message 10 of 14
Phil.E
Thanks again. Sorry I can't figure this out right now.
If you do get any more crashes, please send the reports and if you have time, let me know what the report numbers are so I can add them to the case I have to log here.
(ref: FUS-77707)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 14
Phil.E
We're still looking into this. The developers want me to ask, to double check a couple things.
Can you please open the add-ins dialog, from Tools > Add-Ins > menu. Click on the Add-Ins tab and make a screen shot of it?
Also check if you have Autodesk Screencast installed and check the version number in the about box.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 12 of 14
kyle4L9E9
So it seems there were some add ins there, I don't recall adding them but I must have at some point (unless they come as default?). Anyway I have disabled them and the problem remains the same.
I've just installed Autodesk Screencast then so I can get you a video from it. I've shared a private screencast with you (https://autode.sk/36GYP1x) showing the opening process, with it all working for a F3d and then failing for a STEP and a STP.
This is my version of screencast
Thanks for continuing to look into this.
Cheers,
Kyle
Message 13 of 14
Phil.E
Thanks for that.
It brings to mind something we need to check. When you cannot select anything, what is on the Selection Filter menu? Open the select menu, and look at the last entry, it shows a flyout of all the active selection filters while a command is running. In your case, it might show every item on the list is not ticked. You'd get the same selection behavior if something turned off the entire filter set, which is possible. You can see the tick box to turn them all on/off right there.
Which brings me to my next hunch. The addins list you show has default addins, all but one. PointAtCoord is looking very related to your workflow (see the description of what it does). Even after installing it I cannot reproduce the effect. If you right click on it in the add-ins list an option to find it's folder pops up. I wonder if deleting it entirely might help at this point.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 14 of 14
kyle4L9E9
Yep, so I've deleted PointAtCoord, still the same issue unfortunately.
Selection filters are as such (screenshot taken while the issue was occurring, although on a different file):
Worth noting though that while it may not be obvious in that screencast I sent you, after opening the Step files I am attempting to rotate them (much like I do with the F3d at the start of the cast) and they refuse to move for that.
Quite the conundrum it seems!
Cheers,
Kyle
