Upload from Inventor to 360 view orientation
Mustang69
Mustang69
I using 360 when I want to share a model with a customer but I do all the design in Inventor
To upload the model to 360 I first convert it to a STEP file
Then I upload the STEP file to 360
In Inventor the view orientation is correct  like this
But when I uploaded the STEP file the model are on its back like this
So something is changed during this process
How should I do to get the model in correct orientation?
https://a360.co/3aXEwBX
I can't find a way to change the orientation in 360 and save it
TheCADWhisperer
I don't understand why you are converting to STEP.
For your described need can't you simply use https://viewer.autodesk.com/
Autodesk Viewer | Free Online File Viewer
https://autode.sk/3NRud0Z
...alternatively - they could reset the view cube.
Mustang69
I don't understand why I need to convert either!
It does not work uploading a iam file.
What do you mean I should do from Inventor
You can't reset the view cube since when I leave the 360 it do not keep that view.
Our customer I can't learn how to do this
TheCADWhisperer
In Inventor an assembly file *.iam is merely a set of instructions on how to put the parts together.
You must also upload the parts (*.ipt files).
Upload the ENTIRE assembly, including the parts (or project folder).
Mustang69
Yes and that's why it is much more quicker to upload a STEP.
Alot easier for customer to download a STEP also since many have other 3D system
