Updating parameters from external file
infinitelyExplosive
infinitelyExplosive
Is there any way of updating the parameters in a design programmatically? I tried to use the "Import Parameters" button, but it renames the incoming parameters rather than updating the existing ones. (e.g. L5 becomes L5_1)
I have a relatively large number of parameters in a file and manually editing them will be very tedious.
dsouzasujay
Hi @infinitelyExplosive
Can you please attach the .csv file that you are importing, attach it to next reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
