Update fails to complete
rickFRMW4
Message 1 of 9
rickFRMW4
My internet connection is fine and restarting does not fix the issue.
Replies (8)
Message 2 of 9
jhackney1972
I would appear you do not have enough hard drive space for the application to complete.  Here is the error taken from your log file.
John Hackney, Retired
Message 3 of 9
DougPug
Observer
Observer
Having the same issue with an error msg to check my internet connection and Fusion won't update.
Message 4 of 9
RajkumarIlanchelian
@DougPug In your case it seems to be network related. Here is what you can try:
1. Close and make sure Fusion is not running
2. Restart machine
3. Go to add/remove program - Fusion - Modify
4. In the service utility that gets launched - Run repair Fusion
This should get you going.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
DougPug
Observer
Observer
Thanks, that updated without any issues.
Message 6 of 9
RajkumarIlanchelian
@DougPug Glad to know that the update worked.
Autodesk Fusion
Join Fusion Insider
Message 7 of 9
rickFRMW4
I think you may be right Jack. Thanks.
Message 8 of 9
andreas_4VZ35
I tried to repair fusion and also multiple restarts did not help. It fails to update and also to repair. New Installation also fails.
Message 9 of 9
RajkumarIlanchelian
@andreas_4VZ35 Replied to your other thread.
Autodesk Fusion
Join Fusion Insider
