Update failed
Update failed
asmhome
Observer Observer
Update failed
asmhome
Observer
Observer
Designs created on my other computer will not load.  Also, an update message is found, however update does not complete.  It gets to 98% they fails.  I have tried many times.  I also tried to reinstall Fusion 360, but get a similar error.  I have attached my log
dooyoul_chung
Hi @asmhome
Thank you for sharing log file.
Based on log file, your %localappdata% folder set as read only. So update won't able to update some of file under
%localappdata%\Autodesk\webdeploy\production.
Could you make sure your %localappdata% folder has access right and try again?
Try to reboot your machine to see this issue happen due to the OS issue.
asmhome
Observer
Observer
I found a way to resolve the issue. I uninstalled Fusion 360, then
followed online instructions to manually remove a dozen or so directories
in AppData.
The reinstall worked fine. All issues seem normal now.
I do have a "hobby-ist" personal free version I must renew each year. For
some reason the trial date has been reset and is counting down from 28 days
again. I am assuming I will be able to renew my free version once it gets
to 0 days like I normally did before.
