update failed
update failed
salesFUL6L
Message 1 of 8
update failed
salesFUL6L
I have restarted the computer multiple times and still failed to complete update.
Replies (7)
Message 2 of 8
dsouzasujay
Hi @salesFUL6L
Sorry to see that you're facing this problem.
Could you please follow below article and see if the problem get fix?
Repair Fusion 360 from Fusion 360 Service Utility
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 8
salesFUL6L
Was not able to repair. It says server problem WinError3.
Message 4 of 8
dsouzasujay
Hi @salesFUL6L
I saw 2 sessions of Fusion 360 started almost simultaneously. Currently I don’t have idea what may cause this situation.
Can you please try
If you still not able to Launch Fusion 360 then please share latest autodesk.webdeploy.streamer.log
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 8
salesFUL6L
I tried to uninstall multiple times but it doesn't uninstall.
Message 6 of 8
dsouzasujay
@salesFUL6L
When you say 'doesn't uninstall'. Does the uninstall process starts? do you get any error message while uninstalling?
Could you provide more details?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 8
salesFUL6L
The uninstall process starts, a fusion 360 window flashes and disappears and there is no error message.
Message 8 of 8
dooyoul_chung
Hi @salesFUL6L
If you still have problem uninstalling Fusion 360 then try install again after remove folder %localappdata%\autodesk\webdeploy
Hope this works for you.
Thanks.
