Update failed to complete
info9NV4Q
Observer Observer
info9NV4Q
Observer
Observer
Unable to complete fusion360 update. some of the most annoying issues I'm having now include:
 - program crashed when trying to generate 2d drawings or open old 2d drawings
- program won't import McMasterCarr parts (I tried all solid formats)
- program Wong show dimensions in sketches
Attached diagnostic log files.
RajkumarIlanchelian
@info9NV4Q Thank you for the log files.
The logs show that you are on a very old build 2.0.5790 that was released in May of 2019. Can you confirm?
if this is true, the update will certainly fail. You will have to uninstall Fusions and reinstall and moving forward you should be able to pick up the newer updates correctly.
if you are not on that build then I have to dig into the logs a bit more.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
aleximm
Community Visitor
Community Visitor
Guten Tag,
Ich habe das gleiche Problem!
MFG Alexander Kürzel
