Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Update failed on Mac
wwherling
wwherling
Update from version
Fusion 2.0.20508 x86_64 [Native]
Active Plan: Personal
macOS 15.4.1 (24E263) on iMac20,1
failed.  Failed again after restarting computer. .log filed attached.
RajkumarIlanchelian
@wwherling Can you please try the following?
1. Close Fusion
2. Restart Mac
3. Go to launchpad - Fusion service utility
Run the repair Fusion. Does this help?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
wwherling
This did not work. It generated the following error message: url open error [Errno 9] Bad file descriptor
RajkumarIlanchelian
wwherling
This does not help.  If OneDrive is on my Mac, I can not find it.  If I need an installer to update, I can not find it.
RajkumarIlanchelian
@wwherling one more shot here:
  1. Logout and Close Fusion
    2. Go to Launchpad - Uninstall Fusion
    3. Go to
  • Macintosh HD>Users>(username)>Library>Application Support>Autodesk>Autodesk Fusion 360>
  1. DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
  2. Delete the Fusion launch icon (from desktop or where you have it)
  3. Restart the Mac
  4. Download the installer again
  5. Now install Fusion
Autodesk Fusion
Join Fusion Insider
wwherling
This finally did work but not before I turned off Intego NetBarrier. I do not know why it was necessary to turn off the Intego software as I was able to install initially back in September without turning it off. At any rate, I am up and running with the updated version of Fusion.  Thank you for your help in guiding me to this solution.
