Unit Conversion in Dimension Tool
powerflexplacement
powerflexplacement
Our workplace has been moving from Solidworks over to Fusion360,
On Solidworks, when you are dimensioning a feature on a part, and have units set to mm, if you enter 3/4" it will dimension it to that, and automatically convert it to mm and display it in mm, so entering 3/4" or 3/4in will give an output of 19.05mm
Any ideas on how to do the same in Fusion360? I've tried the above but doesn't seem to work...
nick.narzinski
decimals with units will work.  so 0.75in will convert to mm
powerflexplacement
perfect, thank you
HughesTooling
Another way if you don't know the decimal number is enter it as 3"/4.
Mark Hughes
Owner, Hughes Tooling
