Uninstall cleaner tool won't open
isaacpollak
Message 1 of 11
isaacpollak
I originally ran into a problem where I was unable to export drawings as PDFs. I'd click the OK button, but no file would be written. After searching the forums, it seemed like the solution was a clean install. I downloaded the cleaner tool from the support page, but after unzipping, it won't open. I don't get the "Fusion 360 Cleaner can't be opened because it is from an unidentified developer" error - it's just a generic error that says "The application Fusion 360 Cleaner can't be opened" and I am not given any option to "open anyway" in system preferences. I'm on a mac running OSX 10.15.7. Any ideas?
Replies (10)
Message 2 of 11
dsouzasujay
Hi @isaacpollak ,
Follow Below steps
  1. Download "Automatic Uninstall cleaner tool"
  2. Keep it on the desktop
  3. Make sure to remove spaces (for example rename it to "Fusion_360_Cleaner.app")
  4. Open Terminal and enter below line.
    sudo chmod -R 755 /Users/<YOUR USERNAME>/Desktop/Fusion_360_Cleaner.app
  5. Make sure to change your username in the above line.
  6. Hit enter.
  7. Enter your password.
  8. Hit enter.
  9. Now Try to open Fusion_360_Cleaner.app
Let me know if this works
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 11
isaacpollak
When tried to rename the cleaner to "Fusion_360-Cleaner.app", the .app extension disappears after I hit 'enter'. Then in terminal, when I enter the command you suggested, I get a response saying "No such file or directory".
Message 4 of 11
dsouzasujay
Hi @isaacpollak ,
Can you please share the screenshots of
  1. Terminal with command line and
  2. The ""Fusion_360-Cleaner.app" which is on the desktop
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 5 of 11
isaacpollak
Thanks for your quick replies. Here are the screenshots:
Message 6 of 11
dsouzasujay
Hi @isaacpollak ,
Remove the <>
  1. Copy  below lines and Paste them in terminal
  2. Press enter
  3. Enter your Machine password
  4. Press enter
sudo chmod -R 755 /Users/isaacpollak/Desktop/Fusion_360_Cleaner.app
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 7 of 11
isaacpollak
Ok that worked! D'oh. But now when I try to open the cleaner app I get a new error saying "Fusion_360_Cleaner is damaged and can't be opened."
Message 8 of 11
dsouzasujay
@isaacpollak
Delete the old uninstall app and download a new copy from here
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 9 of 11
isaacpollak
I deleted the original and and downloaded a new copy, and received the same "Fusion_360_Cleaner is damaged and cannot be opened" error.
Message 10 of 11
dsouzasujay
Hi @isaacpollak ,
Not sure what is happening.
I have created a screencast video, Please follow the same on your machine.
Video
Let me know if it works
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 11 of 11
isaacpollak
Hi @dsouzasujay ,
Thanks for all of your help. I really appreciate it. I followed the instructions of your screencast, but I received the same "Fusion_360_Cleaner is damaged and cannot be opened" error as I have before. I'm at a bit of a loss. Is the problem something with my machine? Some kind of compatibility issue?
