Unification of the objects
I need a little help. I´m just elementary in Fusion, so I belive, that will not be so though.
I have an object made of two parts (Bottom, Top). I´ve created the Top part by Revolve function, so it has different
atributes than the Bottom part. Now, I need to combine these two parts together, but I ´m not able to select the Top part. I need them to be together due to the cutting that I´d like to perform with them (Make a "negative" form in cylidrical shape).
Thank you very much for you help
Kevin
jeff_strater
your "top" is a surface body, and your "bottom" is a solid body.  You need both to be solid to use Combine to join them.  Be sure you use commands from the Solid tab:
Jeff Strater
Engineering Director
Thank you, very much!
Now I see what to do. I applied the Stitch function on the surface body and now I´m able to perform what I need to.
Have a nice day!
Kevin
g-andresen
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
