Unfolding sheet metal error: "curve is broken into two discontinuous pieces"
I have been following along with Peter Doering's excellent video "Fusion 360 - T-Spline tiled sphere". When it comes to refolding a piece of sheet metal combined with a curved body, I encounter the error "curve is broken into two discontinuous pieces".
My steps are:
  1. Create a sketch with a straight line and 90deg arc
  2. Create a sheet metal flange along the arc and bend it
  3. Combine the flange with an existing curved body
  4. Refold
This results in the error "curve is broken into two discontinuous pieces". The error does not occur if I do not combine. Any ideas what I might be doing wrong?
rossjm5075
I'm getting a similar error. Did you ever figure this out? Tks
TheCADWhisperer
@rossjm5075
