Unfold - alter - refold issue
sveinSHLTM
sveinSHLTM
Hello, all
I have a sheet metal box of a certain size. I want to extend the width of this box:
Unfold
Move side wall, the flange line and wall moves
Refold.: Problem: It refolds at the former width, not the extended one.
How do I accomplish this task?
Edit: File attached, rightmost unit is the problem, the wall in question is defolded and the width adjustment is done.
Best regards & thanks in advance
Svein
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
TrippyLighting
While this does not address the sheet metal question you asked, I thought I'd point out that none of your components are properly assembled.
If you want to create a proper assembly, then I would recommend not using the position capture feature at all, but utilize the assembly joints to position components.
