I'm new to Fusion and CNC in general. I'm trying to do a simple drilling toolpath on just a rectangular piece of stock.
I start a sketch and draw a 2-point rectangle with the origin at the bottom left, then extrude that rectangle up in Z to represent the stock piece. Then I select the top face and start a new sketch there to lay out points where I want the holes drilled. First weird thing is that when I enter that second sketch, the coordinates for x and y are not negative.
I create a drill path using the points on the top surface then output gcode using the grbl post processor...but all my x and y moves are negative moves. So if I set my machine to its home at the lower left, the gcode immediately sends it to the limit switches at the lower left. I'm driving myself nuts trying to figure out why this is happening and just can't find the problem. Yes. It's entirely possible I have something set in Fusion wrong, but I can't find what that might be. Any help??
