Undo hotkey does not work in parameters window
asiudaisd
Message 1 of 1
asiudaisd
When I am testing a parametric design.
I like to test changing expressions and then do ctrl+z to undo the change if it breaks the design.
Putting the old value/expression back into the field doesn't unbreak the design, it just recomputes it from the broken state.
So I have to use the undo to fix it, but the undo hotkey doesn't work in the parameters window.
I have to close that window in order to use undo.
If I try using the undo hotkey while focused on the main window, it just closes the parameters window.
Can that be fixed in a future update of fusion 360?
Replies (0)
