Unable to start Fusion 360
Windows 10 system.
I installed download and ran the installer for the latest version. However, when I try to launch it I get the message "Sorry, Fusion was unable to save sufficient data for Offline mode and needs to go Online..."
Followed by "Cannot switch to online mode either. Please check your internet connection. Application will exit now.
I tried uninstalling, restarting my machine, giving full permissions to Fusion in local and roaming folders, yet I get the same errors. I also tried renaming the F folder to F_ with no avail.
I would appreciate any help.
RajkumarIlanchelian
@Anonymous Can you follow this article to see if that helps solve the issue?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@Anonymous We detected another issue in our backend that could have caused this issue. Can you uninstall Fusion 360 and re-install it again, please? We believe this should address the issue.
Autodesk Fusion
Join Fusion Insider
Thank you. Uninstalling, deleting all files in appdata and reinstalling from a new installer fixed this.
