unable to sign in fusion 360 FAO RajkumarIlanchelian
sagar_si1985
Message 1 of 8
sagar_si1985
Post for @RajkumarIlanchelian to help with none login issue
Replies (7)
Message 2 of 8
RajkumarIlanchelian
@sagar_si1985 Thank you for creating the thread. Will look at the logs and get back to you.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
RajkumarIlanchelian
@sagar_si1985 Can you go to the below article and install the zip file on that article for SSO? See if now Fusion login works? If it does not then I will add more steps on how to diagnose this issue.
Autodesk Fusion
Join Fusion Insider
Message 4 of 8
sagar_si1985
do refer to the support article here?
if so I cannot find a zip you refer too.
Message 5 of 8
RajkumarIlanchelian
Message 6 of 8
sagar_si1985
I have installed the file and still get the same sign in issue
Message 7 of 8
RajkumarIlanchelian
@sagar_si1985 Can you please try the below? I am wondering if there is any folders that are not in sync.
Uninstall Fusion. Then,
2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
3. Do not use the same Fusion installer. Can you please download the installer again?
4. Now install again
Autodesk Fusion
Join Fusion Insider
Message 8 of 8
sagar_si1985
I have re downloaded the install file via the FREE Trial instead and it has worked straight away THANK YOU!
