Unable to See Component Name when Exporting Flat Pattern
CMCORE
Message 1 of 1
CMCORE
I'm exporting all my flat patterns as DXFs for the plasma table, and I would like the DXF names to be the same as the component names in Fushion.
However, when the flat pattern is active, the component name is not visible, therefore I'm guessing what the name is when I export the DXF. Obviously, my output DXF names are not matching my component names...
Am I totally missing it? Is there a drop-down I should be clicking on? The properties tab shows "Flat Pattern".
Perhaps the DXF output name by default could be propagated with the component name, because the flat pattern is the component anyways. Thanks in advance!
Replies (0)
