Unable to Press Pull simple sketch
rodU3TN8
rodU3TN8
I made a simple sketch and i lust want to make it longer. The press pull shows a dimension but doesn't change the model?
https://a360.co/48QHbHn
jhackney1972
Press Pull command works fine, you have to change the type, but that is not what you want, it will only thicken the end body.  You simply need to edit your original sketch.
John Hackney, Retired
rodU3TN8
Well I'm sorry I thought automatic would do that. Thanks for explaining
