- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I made a simple sketch and i lust want to make it longer. The press pull shows a dimension but doesn't change the model?
Press Pull command works fine, you have to change the type, but that is not what you want, it will only thicken the end body. You simply need to edit your original sketch.
John Hackney, Retired
