Unable to install fusion 360 error notadb error file is not database
baga.bff
baga.bff
Community Visitor
Community Visitor
Unable to install fusion 360 error notadb error file is not database.
Please help how i can resolve the issue
RajkumarIlanchelian
@baga.bff Can you please go to open log file location and attach the logs from there?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ricky.l.potter
Community Visitor
Community Visitor
I have the same error and need help, I recently had to rename my user account on Windows 11 so that it didn't contain any blank spaces. I was able to rename my user account but it did not rename the user account folder so I had to follow a guide on Microsoft help, it involves creating a second admin account so I could modify the existing user folder name. I believe this is what I'm leading to this error. I have both Fusion 360 and Autodesk Inventor installed and they both fail to start. The current issue I'm trying is troubleshoot is with Fusion 360.
RajkumarIlanchelian
@ricky.l.potter In the user account that you created newly, have to also renamed the folder? If so can you uninall Fusion, delete the Fusion short cut and then re-install again, please?
Autodesk Fusion
Join Fusion Insider
ricky.l.potter
Community Visitor
Community Visitor
It won't allow me to uninstall.
ricky.l.potter
Community Visitor
Community Visitor
It won't allow me to uninstall, reinstall or run the program in any way, I even manually located the uninstall.wzf
RajkumarIlanchelian
@ricky.l.potter @What error do you see when you try to uninstall?
Autodesk Fusion
Join Fusion Insider
