Unable to Fillet Lines for Creating a Curve Radius
wallmachine
Message 1 of 24
wallmachine
anyone able to confirm why I can't fillet these lines to create a curve radius and a solution.
Replies (23)
Message 21 of 24
wallmachine
Hey @TheCADWhisperer
Would you have any suggestions on the surface project as some curves are not able to be projected. I have attached a video.
Message 22 of 24
TheCADWhisperer
@wallmachine
Enable 3D Sketch
Project>Include 3D Geometry
Sweep (or Pipe) on your 3D Path
Edit:  Oops, I didn't make the Component active - but we'll say I did that to see if you would catch it.  Yeah, we'll go with that.  And I guess you don't need to make 3D active to Include 3D Geometry, but old habit I guess.
Message 23 of 24
TheCADWhisperer
@wallmachine
With Pipe - you don't even really need the 3D sketch path - simply turn off Chain Select and select desired edges...
Same is true for Sweep - you don't really need to create the path sketch, just select the edges to follow.
Message 24 of 24
wallmachine
@TheCADWhisperer
I really appreciate the walk through. I've learned a ton! I replied to myself again 🤔
