Unable to Export DXF
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've searched the topics and don't see any resolution to my issue.
I have a flat sketch used for PLASMA cutting. It's not extruded. Just a sketch.
By saved version 4 i was able to do a simple EXPORT DXF from the right click options menu successfully.
Now that I've had several edits and final sketch update is on Version-11, the system simply crashes and won't do anything. Close and Open and start over is all I have.
It will NOT export. At all.
I have noticed when simply clicking the sketch in the menu tree, the profile shows allot of ghost images from previous versions. My guess is that may be causing an issue? I don't know.
Oh, I saw someone mentioned i could try to do a SAVE AS... then do save as DXF but the instructions don't match so that function is not an option. Can't find that anywhere.
There is no timeline either. Not sure why. Probably because all the sketches are under one sketch?
Any help would be appreciated.
