Unable to edit extrusion length
I'm experiencing something weird which, I believe, was not happening prior the latest update.
I have a design with a medium size history and I want to change the dimension of an extrusion, but no matter what, changing that dimension breaks something and a remove-body feature occurring after the extrusion is unable to select a single body: every attempt at selecting one of the two bodies created selects both, even by re-creating the feature.
I'm sure the extrusion length change creates two separate bodies, but if I execute a merge operation selecting one of the two bodies and a third different body, both bodies are merged to the third. If I create a new remove-body feature, both bodies are removed.
I can invite you to the project to test the behaviour.
masa.minohara
Hi @Anonymous,
Thank you for posting! Could you share a public link to the design with me so that I can take a closer look?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Here is the link: http://a360.co/2iQKQg7
This is version 7, the reported issue was in version 6, I haven't verified if it applies to version 7 as well.
The affected component is `decoBand`
davebYYPCU
I had no trouble with any part of this file, changed the extrusion to 55 deep, no errors, no drama, to the end of the timeline,
What size did you want to change to?
