Recently I made a custom title block to update a large amount of part drawings. These part drawings were created with inches as the units. The goal is to convert them to metric. The title block was created with MM as the standard. I now realize that you cannot mix dimensions so I wanted to change the dimensions on the title block to inches. However, when I update the document properties to be in inches instead of metric, I am still not able to add a new sheet to implement the title block. I noticed it seems fusion 360 is using the read only units when trying to add a new sheet. Is it not possible to change the units on the title block / drawing sheet or is this a bug?
