Unable to Access Project Files
jt26537
Observer Observer
jt26537
Observer
Observer
I recently logged on to fusion in order to make some changes to a few files that were in a Project that had been shared with me. I was the one to create the files and the only person accessing them before, but I can no longer see them in fusion.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi, @jt26537, thanks for posting.
You can check if your files are available there:
  • My Recent Data in the main view of Fusion 360 Data Panel
You can also check if you did not switch to another hub (above the My Recent Data folder).
  • Activity tab after login to your account on myhub.autodesk360.com
  • Local cache folder:
    • Windows: C:\Users\[USER_NAME]\AppData\Local\Autodesk\Autodesk Fusion 360\[INDIVIDUAL_USERS_ID\W.login\F
    • macOS: Macintosh HD > Users > *** > Library > Application Support > Autodesk > Autodesk Fusion 360 > *** > W.Login\F
You can also check this article for more information: Where are my Fusion 360 files stored?
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
