Ultimate Constraints
infoYYJRS
Message 1 of 15
infoYYJRS
Hey Guys,
i have watched Lars Christensen's tutorial on constraints.
https://www.youtube.com/watch?v=pqd_wlz9gpQ&ab_channel=LarsChristensen
I know how important it is to every design so i try to do it aswell.
But i can't get my drawing to get fully constrained and i can not figure out where i go wrong. Is there a tool to check?
Replies (14)
Message 2 of 15
jeff_strater
The technique I use is sketch drag.  Try dragging any of those blue curves, and you can see what is constrained together, and that can help you figure out what constraints need to be added.  I'll take a look at your sketch in a bit and see if I can show the technique.
Jeff Strater
Engineering Director
Message 3 of 15
g-andresen
With all the chaos, it's hard to find a beginning.
First remove all dimensions and make sure that you do not have any open connections (white dots) and double lines.
günther
Message 4 of 15
HughesTooling
Fusion should really be flagging this as over constrained but I guess all the dimensions have just overwhelmed the solver. If you have a right angle triangle with 2 equal lengths you should only need 2 dimensions to fully constrain it.
Not only have you dimensioned 3 sides and a 45° angle but on all three side you have a second set of dimensions (in affect dimensioning the line length twice). I guess you started with the triangle, if that's constrained with just the two 6.124" dimensions, if at any point it changes to unconstrained you have a problem.
You can see starting with a triangle and 2 dimensions you're fully constrained.
You are also adding to the complexity using 2 collinear lines when you could use a single line. Just add a point at the intersection if you need to dimension the intersection. If I was you I'd start again from just the triangle, add lines and fully constrain at each step and if you run into a problem like the main triangle changing to unconstrained come back here with the new design.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 15
HughesTooling
Forgot to add, if you try fixing this design rather than start again you have something odd going on at the bottom corner. If I window select the corner with delete active it selects 16 points, not sure how you ended up with this!
Mark Hughes
Message 6 of 15
jeff_strater
the suggestions by @HughesTooling and @g-andresen are all good.  The first problem seems to be those "point stacks" where you have 2 or more points on top of each other.  Fix those first.  Focus on getting that construction triangle fully constrained, then work top/down on the rest of the sketch.  You will have lots of angle dimensions, but will need more than that.
Jeff Strater
Message 7 of 15
HughesTooling
After cleaning up your sketch, removing duplicate geometry and adding a few construction line to help with symmetry I get this.
Fully constrained, file's attached for reference.
Mark
Mark Hughes
Message 8 of 15
TheCADWhisperer
Here is a slightly different schemata...
Message 9 of 15
infoYYJRS
This is how i ended up. Thanks a lot guys!
@g-andresen
"In the midst of chaos, there is also opportunity. - Sun Tzu
Message 10 of 15
g-andresen
Indeed.
A wisdom that gives hope.
günther
Message 11 of 15
infoYYJRS
I get another little side effect when i mirror the construction
Message 12 of 15
davebYYPCU
Has anyone recommended you Pattern or Mirror in the modelling environment, and doing so in sketch is not recommended?
delete 3/4 of the sketch, and proceed to the modelling area.
I have not reviewed the file.
Message 13 of 15
TheCADWhisperer
What is your end goal?
It is almost always preferable to pattern (mirror is a type of pattern) at the feature or body level rather than at the sketch level.
Explain you Design Intent - show images of existing real world part(s) if possible.
Message 14 of 15
infoYYJRS
So my goal is to create the bracelet on the attached image with the pattern. Both creations are mine right now there are done from illustrator and tooled by an engraver but i would like to be able to draw it in fusion....
Message 15 of 15
TheCADWhisperer
Ahh, I recognize this work now (I don't pay any attention to names, only geometry).
As we discussed months ago - avoid patterns in sketches - keep sketches simple and pattern features, faces or bodies.
