Typo in joint conflicts pop-up
jschrempp
Message 1 of 12
jschrempp
Note the <br/> in the pop up image. Thought you'd want to know.
Jim
Replies (11)
Message 2 of 12
g-andresen
If you share the file, we can analyse the conflict described.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 3 of 12
TrippyLighting
@Phil.E can you send this to the right team please?
Message 4 of 12
jschrempp
This isn't a problem with the joint conflict, I believe one exists. The problem is the spurious HTML tag embedded in the message. I think you could find that in the code.
Message 5 of 12
g-andresen
Embedding in the post is a known problem.
Instead, attach the link to the next post or create an mp4 file and paste it.
günther
Note!
Message 6 of 12
jschrempp
Thanks, I didn't know about that. I guess I don't run into enough bugs! The screen shot is attached.
Message 7 of 12
jschrempp
Message 8 of 12
Steven_Gao
Thanks for letting us know the typo issue. I have created an internal defect(FUS-119909) to ask our development team to fix it.
Steven
Message 9 of 12
Phil.E
Oops, logged a ticket in error. Steven beat me to it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 12
Phil.E
I think your design might be required to reproduce the issue for debugging. None of the testers can get that warning (with the typo) to appear.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 12
jschrempp
Sorry to say I'm a newbie at this and eventually gave up, so I'm not sure what I did. I've tried to reproduce it just now and could not get the same error message; the error I get now is just one line.
In case it helps, I'm attaching a screen shot of my design. The brown components are ground. The green circles show where two working sliding joints are in place. The red circle shows where I was trying to put in a joint and kept getting the error message that I reported. The non-brown components were linked from another design.
If this doesn't help, then we should close this out.
Jim
Message 12 of 12
Phil.E
Thanks. We'll keep looking. The html should show up in a plain text string and be found by searching the code.
Take care,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
