Two separate storage spaces? Disappearing projects
When I create a new project from within Fusion 260, it disappears after 30 seconds or so. If a design is saved there, I can keep saving new iterations and everything seems fine. However, if I close the design, I have no way of getting back to it, except through 'My Recent Data'.
I have tested saving in a premade project such as the Demo Project, and drawings are persistent. Similarly, I can open A360 Hub in a secondary web browser, create a new project there, then save a drawing to that project in F360 and it acts as expected.
I have fortunately managed to find a way to access the disappeared projects - if I have a drawing from one in 'My Recent Data', I am able to press 'View Details on Web' (which opens in my primary browser), then use the navigation buttons to get to 'https://myhub.autodesk360.com/g/all_projects/my' where all the disappeared projects and drawings are visible - but the projects accessible from Fusion (such as the demo project) are not, so I am not able to move or copy drawings between them.
The reason I mention using primary and secondary browsers is that if I try to open my A360 hub directly from the primary one, I get a page saying:
"You are logged in as my-email@gmail.com.
Login as different user"
But accessing it via a design from Fusion works.
My theory is that somehow my account has got two independent project databases attached to it, the primary one, which is visible from Fusion normally, and another one, which is where Fusion saves to. A web browser session can only be connected to one at a time, and if I try to access the other, the Autodesk back end thinks the project is on a different account and doesn't allow access. The only way to access the 'hidden' one is via a link from the Fusion app.
By looking at the URLs, it seems like the default user myhub.autodesk360.com/ue28b7170/g/projects/ has a different ID to the hidden one myhub.autodesk360.com/ue28b7171/g/projects/
Has anyone encountered a similar issue before, and how can I resolve it?
