Two issues in iPad version
salamdahbour
Message 1 of 14
salamdahbour
Two issues in the iPad that have been a problem since version 2.7.1 (over a year ago).  Everything worked great before that version.
Issue 1 - On the Measure tool, the Precision is stuck at 0.1.  To reproduce the issue, select the Measure tool, click the gear icon in the upper right corner, select fraction inches, then select Precision of 0.01.  Repeat the above and you’ll see that the Precision has reset itself to 0.1.  This means that if I measure something thats 3/4”, it gets rounded up to 1”.
Issue 2 - On the Measure tool, the Reset icon appears directly on top of the “3 dots” (part of iOS) in the middle of the top of the iPad.  This takes precedence over the Reset icon.
So if I touch the Reset icon, the menu for the 3 dots pops up (Full screen, Split screen, etc).
Is there any way these can be fixed?  Thanks.
Replies (13)
Message 2 of 14
RajkumarIlanchelian
@salamdahbour I have forwarded this to our team to look into. Thank you for reporting.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 14
salamdahbour
Awesome. Thank you!
Message 4 of 14
bentwookie
Is there even a team to report it to anymore? I'm not really joking.
This particular bug has come up plenty of times here. I've brought it up over on insider to crickets. There are reddit posts about it. It fundamentally breaks one of the few functions the iOS app has (to inspect and measure things, as it can't do much else).
Why have a team, to make an app that you can only use to measure one line once?
(I'm coincidentally hot on this today as I had to make a trip to drag my MacBook into the shop this morning to measure something I should have been able to do on the iPad I drive my CNC with)
Message 5 of 14
rajat_mehtaL58QJ
Hi @salamdahbour @bentwookie ,
I am from the Autodesk Fusion Team . Apologies for the inconvenience you are facing , our team is looking into the issue and will update here as soon as possible.
Rajat
Message 6 of 14
salamdahbour
Great news.  Thanks Rajat!
Message 7 of 14
salamdahbour
Hi Rajat,
Is there any update on this?  Are you getting close to releasing a fix?  Thanks.
Message 8 of 14
rajat_mehtaL58QJ
Hi @salamdahbour ,
Yes my team is working on it , the fix will be available in the next app release , I will update the version number and release date here .
Rajat
Message 9 of 14
salamdahbour
Good news.  Thanks for the update.
Message 10 of 14
salamdahbour
Hi Rajat,
It’s been almost 4 months since we started this chain.  Is there an estimate for when the next version of the Fusion app will be released?
Salam
Message 11 of 14
bentwookie
Today at WWDC they showed off a new multitasking UI for iPads that doesn't appear to have the dot affordance at the top. However, pecision is still broken and phones with notches continue to be degraded in portrait mode.
I suspect Apple will figure out how to hide a camera under the screen and remove the notch before someone at Autodesk bothers to simply right-align a toolbar icon though.
Message 12 of 14
salamdahbour
Thanks for the info!  I guess that’s progress?  I don’t know how you can show something at a conference if it’s broken.  Oh well, maybe it’ll get fixed someday.  Thanks again for the update.
Message 13 of 14
bentwookie
To be clear, Autodesk didn't show their app in the keynote. I'm just suggesting that the dots that were used to enable the multitasking UI, that occlude the measurement clear button, don't seem to be there anymore.
Message 14 of 14
salamdahbour
Got it. For me, the key is that the Precision is stuck at 0.1. I can always get around resetting the measurements. But the fact that the measurement itself is inaccurate makes the entire app not useful.
