Turning a tilted object whose angle I don't know into a right angle
samilutfi_yildiz
samilutfi_yildiz
In my project, I imported a 3D object and the model was tilted in the plane when imported. At first I tried to rotate it with my normal hand, but I didn't know the angle. How can I make it right angle?
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
jhackney1972
Your probably want to use the Align command.  This command is a temporary move so you once you get it into position, you must retain it using some method like pinning or Capture Position.  The great thing about Align, it will snap to planes including Origin planes.
John Hackney, Retired
