Trying to joint sketches/plates at an angle
I have been trying to build a geodesic dome from polygons similar to a soccer ball, and fuse them together into one component to 3d print. H used an online calculator to find the angles needed for the shapes, but it did not give the angles between the polygons/faces. I was wondering if there is a way similar to sketches to set a "constraint" in an assembly between edges so it is free to rotate so I can constraint the other edges of the polygon to form the dome before joining the overlapping parts of the plates.
