Trying to join to bodies with loft but failing
lucas-gsbp
lucas-gsbp
Hi I am trying to create loft that joins these two surfaces
but getting errors:
I have no idea how to proceed.
The end result is to join the two bodies with a chamfer like new surface.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
davebYYPCU
Not quite enough information in the picture, but looks like you are attempting a hollow set of profiles, Fusion has never been able to Loft a donut style wall in one go.
Solid Loft centre profile, to the hole in plate 2.  Then Surface offset the inclined walls at Zero distance.
Surface Sweep, Path and Guide Rail?
Many Lofts Edge to Edge, May also work.
Might help.....
lucas-gsbp
I got it to work by extruding the profile 1 surface to the same level as profile 2 and later I used the shell tool to cut it back. Thanks
