Trying to Copy a Text Block in Sketch makes hard crash
TrollTuner2
TrollTuner2
Trying to MOVE/COPY a Text block crashes.
Its an empty sketch for labeling softjaws.. Just need to copy it for the other jaw..
Fusion 2.0.18220 x86_64
Active Plan: Subscription
Windows 11 Pro 22H2 (22621.3007)
Lenovo 13th  i9-13900  64GB RTX A2000  Workstation.
jhackney1972
Are you in the Manufacturing Environment or the Design Environment when doing this operation?
Edit: I cannot replicate this issue in either environment.  Please attach the model you are having this issue in.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
TrollTuner2
In Design Sketch.  Was a new sketch.
jhackney1972
As I mentioned in my post, I cannot get this to fail, so I asked you to attach your model that it is failing in.
