troulble turning most of a sphere
johnptc314159
Message 1 of 17
johnptc314159
i can not seem to find a solution on how to turn this simple part 😞
i am trying a round insert using center of insert compensation.  it does not  turn a accurate sphere nor spherical sphere. and the 1 inch neck is about 1.24 inch diameter instead of 1 inch.
HELP PLEASE
Replies (16)
Message 2 of 17
johnptc314159
https://a360.co/2ZYguyu    how to tool and turn his part is the basic problem 😞
Message 3 of 17
HughesTooling
The toolpath is calculated to the insert centre you have set in the tool library. How have you set the tool in your lathe? I set my tools up using Tip for compensation type.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 17
johnptc314159
thank-you.  ??  will that work with a round tool ??  also how would you tool this yourself ??
many thanks john
Message 5 of 17
HughesTooling
OK didn't notice roughing will not let you use Tip as the compensation type. @seth.madore  is that by design? Also noticed a bug, if you edit the tool to Tip then change back to insert center the op still fails and there doesn't seem to be a way to fix the op after that.
@johnptc314159  you could turn on the old roughing strategy in preferences and use that instead. Or you'll need to set the tool up on the machine so the center of the tip is zero I guess.
This is the old roughing strategy using tip compensation.
Setting is here in preferences.
Mark
Mark Hughes
Message 6 of 17
johnptc314159
i will try this now 🙂
HOW WOULD YOU TURN THIS PART ?????
thanks
Message 7 of 17
johnptc314159
using insert center in finish mode i got this https://a360.co/3mIjuJ4
there must better a better way....not married to this tool 😞
it seemed like the easy way................
Message 8 of 17
HughesTooling
Only time I've made some ball joints I used a tool like below and set up as tool tangent. I added fillet rads on the part to get around any problems with releaf on the trailing side of the tip.
Mark Hughes
Message 9 of 17
johnptc314159
a million thanks for your help 🙂
Message 10 of 17
seth.madore
Just for the record; we do have a fix in place for the previously mentioned "Tip Error". Wo hope to release it in a future Hotfix..
Seth Madore
Message 11 of 17
johnptc314159
great.... glad to hear 🙂
Message 12 of 17
akash.kamoolkar
Hey guys, the issue of the toolpath not generating has been fixed in the october update.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 13 of 17
johnptc314159
can you use a tool holder ??    many thanks
Message 14 of 17
akash.kamoolkar
@johnptc314159
Yes you can use a holder, why, are you having a problem?
Akash Kamoolkar
Akash Kamoolkar
Message 15 of 17
johnptc314159
yes. using a round insert and toolholder gave just parts.  delete toolholder leave round insert and all worked, parts were very close ( haas st15 lathe)
thanks
Message 16 of 17
johnptc314159
from another thread
Message 20 of 32
in reply to: johnptc
I only glanced at all the posts and went straight for file so I can see what is going on in real time.
Here is what I learned, selecting round insert and trying to define holder in old tool library has a problem.
I cannot select custom holder and that prevents tool from being able to undercut back side.
The solution is to use round insert without the holder.
Noticed I also used 35 degree tool leading up to that conclusion.
In 99 % of my turning work I use tip tangent as that is in sink with how tools are touched off in machine.
You can also use center of round insert but after touching off tip of insert in machine you need to shift X and Z values to be in sink with programmed point.
Message 17 of 17
johnptc314159
other thread title   "additional cam bug @seth.madore"
